Results 1 to 9 of 9
    Default Please help, computer wont recognize phone
    i have a verizon GS3 and when i connect it to any computer it recognizes it as a cd drive, i have installed and uninstalled and reinstalled the correct drivers but still nothing, i cant figure it out. Please help me its so annoying, i need to back up everything on my phone cuz i want to do a clean wipe and install a rom
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Please help, computer wont recognize phone
    I assume the USB connection is on Mass Storage?
    Is there any data other than app data on the Internal Storage that you actually need? If everything is on the SD card, you can use a card reader.
    Yea it's on the mtp thing
    Not really, I can transfer those things on the phone but I don't want to have to be taking out my sdcard every time I wanna put something on my phone
    Did I do something wrong on my phone cuz it didn't do that before
  4. #4
    Ricky Babalu's Avatar
    BEACH BUM
    Posts
    ROM
    Stock : Rooted, Unlocked
    What operating system do you have? In order for MTP to work you have to have Windows Media Player 10 or above (if on XP). Did you reboot PC after installing drivers? Also, try a USB connection in back of PC not the front.
    Make sure whatever system you have is up to date. In "Device Manager" make sure the drivers are listed and installed properly (no triangles).
  5. #5
    I don't have an S3, so I don't know for sure what selections are in your USB connection menu--but is there an option for "USB Mass Storage" or "Disk Drive" that is separate from MTP? They're not exactly the same, and when Devinator asked if you were set to Mass Storage, you replied that you were set to MTP. The ideal setting to see your phone as a drive is USB Mass Storage.
    For my RAZR Maxx, I notice occasional recognition delays when plugging it into my PC. It may take up to 30 seconds for it to show up, and sometimes I have to unplug it and plug it back in again for it to register.
  6. #6
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Same with my X2. Sometimes it takes 30 seconds.
    Sent from my DROID X2 using Android Central Forums
    No there's no option for mass storage that I know of, is there some MTP divers that I need?
    I've connected to 4 different computers, I tried it on vista, Windows 7 and 8 and the same thing happens, that's why I'm thinking it's my phone. I've tried all USB ports and before only one would recognize it and now none of them do
  8. #8
    I assume you've tried rebooting the phone already? If all else fails, a factory reset would probably do the trick, although it's a hassle.
    Sent from my ASUS Transformer Pad TF300T using Android Central Forums
  9. #9
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by B. Diddy View Post
    OP wants to get a custom ROM on there anyway.
    Quote Originally Posted by lilrob429 View Post
    Well, you can always do it once, then try and get the new ROM on there and see if that fixes the problem.
  1. Unrooting Thunderbolt Revolutonary Wont Recognize Phone HELP
    By tmijares95 in forum Verizon HTC Thunderbolt
    Last Post: 04-06-2012, 11:21 AM
  2. Computer not recognizing phone when in USB Debugging mode
    By sinfony78 in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 06-04-2011, 01:38 PM
  3. Please help-Bricked wife's phone
    By jparaja in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 04-17-2011, 09:44 PM
  4. Replies: 0
    Last Post: 08-14-2010, 11:08 PM
  5. Please Help!: Problem with replacing phone on 30 day warranty
    By thewaterballoonist in forum HTC EVO 4G
    Last Post: 07-14-2010, 11:26 PM
