Results 1 to 6 of 6
    Chewie18's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How do I forward email on Droid X?
    I just got a Droid X and I am trying to forward an e-mail that I have recieved. I am sure that it's very easy but for some reason I just don't see it.
    How do I do this?
  2. #2
    takeshi's Avatar
    Posts
    Global Posts
    1,607 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    In the stock email app?
    Chewie18's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes... I would think that it would be plain as day. But I just don't see it.
  4. #4
    albertdc's Avatar
    Posts
    Global Posts
    372 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    At least with the stock gmail app, if you scroll to the bottom of the message, you will see "reply", 'reply all", and "forward" options. These scroll with the email message and will appear just above the static "archive, delete, older" butons.
    If you are not usnig the gmail app, then I'm sorry I don't know.
  5. #5
    tmelland's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Forwarding E-mail on Droid X
    At the top of each E-mail you receive in your GMAIL on your Droid X, there will be a rectangular box in the top upper right portion of the screen. This rectangular box contains a star which I would assume means add to Favorites, an arrow pointing to the left which is a "reply" function and then the small left pointer on the far right of the rectangular box which toggles and expands the box and reveals the 'FORWARD" function along with the "Reply" and "Reply All" functions.
  6. #6
    truslide's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    All android applications are the same. I don't use email... but, it shouldn't differ from the gmail app, or someone else's emil app for that mAtter. After you open the message, look for a fwd button either in the msg, or in the menu. Anyone cM answer this question tho since its an ANDROID email application. I only have a gmail account :-( don't like too many email addresses.
