Results 1 to 8 of 8
- 02-07-2013, 10:21 AM
Thread Author #1
2 Users = 2 Purchases?
I just added my wife as a user on my Nexus 7 that has over a hundred dollars worth of apps already installed on that device.
My motivation was to set up a safe environment where she could learn and get used to the android
However, when I switch to her user interface, it appears that there is no way to access the apps already installed on the device other than to repurchase them and searches have not turned up any information on this restriction.
Anyone able to point me to additional information?
Thanks in advance,
Beverly Howard - 02-07-2013, 10:26 AM #2
Re: 2 Users = 2 Purchases?
Play store app purchases are link to the Google email address used to purchase them. If she is using a separate email address and no she will not have access to purchase and download apps on the device. This is due to the access credentials being linked to your email address not to hers. If you want her to be able to use these apps she will need to use your account or repurchase them.
Sent from my Droid Razr Maxx!! - 02-07-2013, 10:34 AM
Thread Author #3
Thanks for the confirmation. Unfortunate that it means that there is really no easy way to set up a learning environment... i.e. using my email address means email, contacts, calendar, etc, etc would all be mine and not much motivation to set up a second user.
Thanks again,
Beverly Howard - 02-07-2013, 10:53 AM #4
You are correct. On a secure stand point its good but a share point not.
Sent from my Droid Razr Maxx!! - 02-07-2013, 11:51 AM
Thread Author #5
Understood...
At 70, the 7" screen is a valuable learning tool for both of us since it's not a huge struggle to "see" what's going on during the learning and familiarization process (she's due for a nexus4)
So, as a workaround on the 7, I had already set her up under her gmail account where's she's learning the sync apps and a few others, and, following your post, found that it's possible to create a third user under my account name which will allow options so that she can thrash about with no danger to "my stuff" and determine what she wants when her new phone arrives.
Thanks again,
Beverly Howard - 02-07-2013, 12:17 PM #6
- 02-07-2013, 07:18 PM #7
- 02-08-2013, 07:24 AM
Thread Author #8
Video Purchasing for UK Users
By JimboDeany in forum Google Nexus 7 TabletReplies: 0Last Post: 11-14-2012, 10:38 AM -
iPhone user purchased a Galaxy Tab
By chazm in forum Samsung Galaxy Tab 10-inchReplies: 9Last Post: 10-19-2011, 08:59 PM -
Droid launch kit PDF and user manual PDF.
By Jesse Potter in forum Motorola DroidReplies: 13Last Post: 11-08-2009, 01:55 AM -
New user
By Magellan in forum IntroductionsReplies: 2Last Post: 08-31-2009, 09:17 PM -
Considering G1 purchase
By glisk in forum T-Mobile G1Replies: 10Last Post: 12-22-2008, 11:01 AM
Reply
