Results 1 to 2 of 2
    djhayes's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nexus 4 won't save contacts
    In the past couple weeks my nexus has stopped saving contacts that I add. This is regardless of how I add the contact, and I am sure that I have my Google account selected as the one to save to.
    I'm curious if anyone else has had this problem, and what the impact of 'resetting' the phone is. Will I need to reinstall all my apps and widgets?
    Thank you
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock/Stock/CM9
    Default Re: Nexus 4 won't save contacts
    I had this problem the other day. Couldn't save a contact, no matter what. When I rebooted my phone, everything was fine.
    Yes, you will need to reinstall apps. It is possible to have that backed up with something like Titanium Backup, but, I believe you need to be rooted.
  1. Nexus S won't sync contacts anymore
    By MrtnD in forum T-Mobile Nexus S
    Last Post: 10-02-2014, 10:54 AM
  2. need help contacts won't save
    By dsihalath in forum General Help and How To
    Last Post: 12-06-2010, 03:36 AM
  3. Google Search Widget won't Select contacts?
    By HumanMachine in forum Motorola Droid X
    Last Post: 09-29-2010, 03:54 PM
  4. Cameras won't save
    By sweetman in forum Motorola Droid
    Last Post: 09-14-2010, 08:35 AM
  5. Saving Contact after Phone Call
    By krelvinaz in forum Verizon Droid Incredible
    Last Post: 05-22-2010, 10:11 AM
