Results 1 to 3 of 3
- 02-07-2013, 11:09 PM
Thread Author #1
battery issues
my husband has just bought the galaxy note and he is finding that the wifi and the 4g where he works is very weak with this being said he cant toogle between the 2 gets e and then wifi then 4g its draining the battery so bad its nuts he wants to use this for texting or facebook while at work what can we do please help we tried the ultimate juice defender that did nothing very upsetting since we just came from iphones
- 02-08-2013, 12:06 AM #2
- 02-08-2013, 02:38 AM #3
Re: battery issues
I agree, just pick one data access and stick with it. While it may keep bouncing in and out, just one doing it is still better than 3 (wifi, 3G and 4G each have their often radios drawing power). The point about turning 4G off and only using 3G is also very true for reception and power consumption is also very true.
A different type of Battery Issue
By alexgtp in forum Verizon Droid IncredibleReplies: 2Last Post: 05-22-2010, 04:07 PM -
Tried and true fix for battery issue
By andyandroid in forum Verizon Droid IncredibleReplies: 219Last Post: 05-19-2010, 02:00 PM -
Koush's Rom Battery Issues
By tuxedojacob in forum Motorola Droid Rooting, ROMs and HacksReplies: 8Last Post: 05-04-2010, 10:59 AM -
Droid Restart/Battery Issue
By Dapke36 in forum Motorola DroidReplies: 11Last Post: 02-09-2010, 11:40 AM -
Weird Battery Issue?
By jacob.downey in forum Google / HTC Nexus OneReplies: 1Last Post: 01-30-2010, 03:24 PM
Reply
