Results 1 to 1 of 1
- 02-08-2013, 11:21 AM
Thread Author #1
Help with Mantano reader
Is anybody having this problem and or know how to fix it. In Mantano, when I select a word, that I want defined, and use any of the web selections ( google, wikipedia, wiktionary ) it crashes the second time I try to use it. The first time it works and I can scroll the page up and down. The second time I try to use it, as soon as I try to scroll the screen, it crashes out to a report screen. If I use the embedded dictionary it works fine with no problems, it just seems to be in the web options where I have the crash. I can make the crash happen every time and it isnt random. I also have contacted mantano and havent heard from them and its been over a week. Not to mention this isnt the first time Ive contacted them about this. I would appreciate any feedback. Thanks.
Sent from my Nexus 7 using Tapatalk HD
Need help with N7 reader app
By bradnwa in forum Google Nexus 7 TabletReplies: 1Last Post: 11-14-2012, 07:07 AM -
Fellow PSU users in here? help with email?
By mdc5162 in forum Motorola DroidReplies: 15Last Post: 09-02-2010, 11:51 AM -
Need Help With Eris Signal !!
By m.j.h.#ac in forum HTC Droid ErisReplies: 1Last Post: 11-13-2009, 07:03 PM -
Need Help with Facebook App
By olson0827#ac in forum Android ApplicationsReplies: 1Last Post: 11-11-2009, 09:25 PM -
Need help with Blackberry calender/scheduler to Droid
By buckeye#ac in forum General Help and How ToReplies: 0Last Post: 11-09-2009, 04:01 PM
Reply
