Results 1 to 2 of 2
- 02-08-2013, 07:04 PM
Thread Author #1
market store no longer reacts to build.prop changes or market enabler after external ad switch
title should read external AD switch
market enabler was working fine on my device as was editing build. prop to spoof a different phone. but, after running a script to swap my internal and external memory neither no longer works.
even though my phone says it's switched markets and the model is different the play store doesn't recognize these changes and only shows the default.
I first tried wiping the data for the store, clearing the cache, reinstalling the store, but no changes...
I then tried restoring to before the backup which removed the script, but my play store is still messed up. I even did a factory reset but nothing seems to help. any ideas on what to try next? my use for an android drops dramatically if I can't access the Japanese play store...D= - 02-10-2013, 10:45 AM
Thread Author #2
no longer possible to wake up phone with volume buttons after ICS
By centerwaters in forum Verizon HTC RezoundReplies: 17Last Post: 08-05-2012, 02:18 PM -
Blue Tooth Issue, no longer able to explore files on phone
By ammaralo in forum LG Optimus SReplies: 4Last Post: 02-02-2011, 07:55 AM -
After linking contacts to facebook, they're no longer able to be found in My Contacts
By justavillain in forum HTC EVO 4GReplies: 5Last Post: 01-23-2011, 01:08 PM -
BetterCut no longer seems to be working...
By kaivorb in forum HTC EVO 4GReplies: 7Last Post: 08-16-2010, 12:09 PM -
no longer able to turn off background data?
By mps623 in forum Motorola DroidReplies: 1Last Post: 01-19-2010, 12:16 PM
Reply
