Results 1 to 3 of 3
- 02-09-2013, 11:20 AM
Thread Author #1
Still Confused about Android Wallpaper
New member so please be gentle. :)
I have read numerous posts on several forums about how to get
wallpaper to fit an Android device without cropping. I still
have not had success.
I understand that stock Android crops to make images fit. But if
I am using an image with the same resolution as my device, why would
it need to crop at all? I want the whole image to be my wallpaper. Both of
my devices run Jellybean.
Samsung Galaxy S3 resolution is 720 x 1280.
Asus Transformer Infinity is 1920 x 1200.
But if I use an image the same size it still crops it so only a small
portion of the image is visible. And this is for a non-scrolling
wallpaper just on the home screen.
I tried Quickpic and it allowed me to select more of the image (a larger
square) but it still cut off the sides. Then when I applied it, the top
and bottom were cut off too on the home screen.
I was going to try PicSpeed but recent reviews of the last update say its
crop feature is no longer working for full images.
So how can I get a 720 x 1280 on my S3 or a 1920 x 1200 on my Infinity
without losing large chunks of the image?
Thanks for any help. - 02-10-2013, 06:06 AM #2
Re: Still Confused about Android Wallpaper
You don't have to crop it though.. When you press on set as wallpaper a blue frame will show up and than you can resize that frame to put it around what you want.. If that didn't work.. Try Nova Launcher.. I haven't used touchwiz for awhile so I don't know how to do that on it ..
Note : all what I said is for your galaxy s3 - 02-11-2013, 11:35 AM
Thread Author #3
New to Android and Samsung and confused about flash
By 300pete in forum Samsung Galaxy Tab 10-inchReplies: 6Last Post: 02-01-2013, 12:04 AM -
whata so confusing about android?
By Irvgotti in forum General Help and How ToReplies: 7Last Post: 09-13-2012, 06:06 AM -
Confusion about my version of Android
By JamesKBoyd in forum HTC EVO 4GReplies: 2Last Post: 02-24-2011, 08:00 AM -
Hi, some questions about Android
By zeravla531 in forum HTC HeroReplies: 7Last Post: 10-12-2009, 05:47 PM -
Questions about android handsets
By mills1540 in forum The Android Central LoungeReplies: 1Last Post: 08-16-2009, 09:23 PM
Reply
