International versions vs regular?
Ironarm
7
On Negri Electronics' site, on some phones, in a bold red highlight it says "This device is intended for international use only!" what does that mean? What is the difference between an international version and a regular version? I'm pretty new to the smartphone world to I'm a bit confused.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
If may refer to devices that operate on the network of international carriers versus stateside carriers. What device are you looking at and what country do you live in?
Shadowriver
697
9
Odp: International versions vs regular?
There is no diffrence as long its GSM device and you plan to use it in gsm network which TMobile is, you just need to look out on supported frequences, use model numbers insted of phone names to check them out.
All gsm phones should on any gsm network atleast in 2G
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: Odp: International versions vs regular?
The SGH-T889 supports T-Mobile 1700/2100 so you should be okay.
bjammmin007
