Results 1 to 10 of 10
    Default Need Help With New S3
    First off howdy everyone! I recently had a friend sell me his Galaxy S3. He rooted it with something like Liquid Smooth i believe. I'm trying to unroot the phone and put it back to factory settings. How can this be done? I've tried the hold down power button, home button, and volume up button down at the same time and got to a menu. There I tapped on factory wipe i believe but after it powers up the root is still there. Please any info would be great.
  2. #2
    mhinc's Avatar
    Posts
    Global Posts
    448 Global Posts
    Default Re: Need Help With New S3
    Quote Originally Posted by SeizeA7X View Post
    It's my understanding that you would have to use the same software that was used to root, to restore it to normal. So I would make sure it was Liquid Smooth, install it and unroot then do a factory reset.
    Samsung Galaxy S3 SGH-I747M JB 4.1.1
    LG Nexus 4 JB 4.2.1
    Would anyone happen to know where I could download the Liquid Smooth root software so I could restore it to normal?
  4. #4
    mhinc's Avatar
    Posts
    Global Posts
    448 Global Posts
    LG Nexus 4 JB 4.2.1
  5. #5
    DroidXcon's Avatar
    Posts
    ROM
    Stock for now
    Quote Originally Posted by mhinc View Post
    Flashing the above would most likely brick his device since it is a Galaxy Nexus Rom and not meant for the S3.
    You need to provide us with what model S3 you have as returning to stock will be different per carrier and model. you can either provide us with the information here in this thread or go to the S3 forums and find your carrier model , look for the answer there or ask in your specific carrier S3 variant
    http://forums.androidcentral.com/samsung-galaxy-s3/
    If i've made life easier buy me a Macchiato
    I have the Verizon S3 SCH-i535
  7. #7
    DroidXcon's Avatar
    Posts
    ROM
    Stock for now
    you can follow the directions here to return to stock
    [GUIDE] Restore Back to Clean Factory Stock UPDATE 10/23
    if you need help message me and let me know and ill do my best to assist you
  8. Thread Author  Thread Author    #8
    This seems like such a long and tedious process just to put it back to normal - seems like such a risk
  9. #9
    DroidXcon's Avatar
    Posts
    ROM
    Stock for now
    Its actually very simple just seems long .
    From my Galaxy Note 2 via Tapatalk
  10. #10
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    The question is why you want to "unroot" the phone. Being rooted doesn't do anything that would prevent you from using the phone as an unrooted phone.
    (BTW, flashing a new ROM and rooting aren't the same thing, although almost all ROMs are rooted.)
  1. Need help with my S3
    By briancook451 in forum Samsung Galaxy S3
    Last Post: 08-10-2012, 08:18 AM
  2. Need help with new skyrocket
    By pabowhunter in forum Samsung Galaxy S II Skyrocket
    Last Post: 05-02-2012, 10:03 PM
  3. need help with new skype update
    By weezysaid in forum Verizon Droid Incredible
    Last Post: 04-30-2012, 10:40 PM
  4. Please need help with new DROID BIONIC
    By GO2SHH in forum General Help and How To
    Last Post: 11-06-2011, 01:23 AM
  5. Need help with new Handbrake
    By zrxoa1 in forum Verizon Droid Incredible
    Last Post: 12-31-2010, 03:24 AM
