1. megamef's Avatar
    The weather app isn't updating my current location but updates the other location I have saved.. it recognizes when I go to a different city, but doesn't show temperature. does anyone know why?
    07-26-2010 07:01 PM
  2. PvilleComp's Avatar
    Check the settings in the Weather app/widgit, is there an update interval? I know the HTC Sense weather widget has one and it can be set from every hour update to once daily.
    Hope this helps.
    07-26-2010 10:48 PM
  3. REDDEVILVS's Avatar
    The same thing has happened to me on my Aria..only the last week...I find that if I manuelly go into my Home screen weahter and hit refresh it updates it fine....but only for a few days and then the issue is back...
    07-26-2010 11:09 PM
  4. megamef's Avatar
    Yes I tried both and still not updating.. I manually hit the refresh button, as well as went into options and changed the update time.. its been like this for almost a week.. I have Droid incredible.. its weird cause the location that came preset (new york) is updating, but my current location weather isn't.. I mean it recognizes when I am another city, but doesn't show temp
    07-27-2010 06:50 AM
  5. PvilleComp's Avatar
    That's bizarre. Are you in a remote area where AccuWeather may not have data? Does the Weather Channel widget update? I have found that the Weather Channel app is way more accurate then the AccuWeather widget in Sense.
    07-27-2010 08:39 AM
  6. megamef's Avatar
    I haven't had a problem with the sense weather app, always worked and updated until now.. I live right outside Atlantic city.
    07-27-2010 08:47 AM
  7. megamef's Avatar
    I got it.. all I had to do was go to accounts&sync then re-sync it.. thanks for the help tho
    07-29-2010 11:50 AM
  8. praegler's Avatar
    Has anyone else had this problem?
    I select the weather part of the HTC Clock/Weather widge. I then go into the settings and "Update automatically" is unchecked. I check it and exit out. Then when I go back in it is unchecked again. This is causing the thing to not auto update. If I hit the refresh it pulls the weather and works fine, just will not auto refresh.
    Never mind I found the problem:
    you have to go into the phone settings, "Accounts and Sync", and make sure "background data" and "Auto-sync" are checked. Then turn on the auto sync in the weather widget and it stays checked.
    08-31-2010 07:55 AM
