Results 1 to 7 of 7
- 02-12-2013, 08:25 PM
Thread Author #1
Personalized Message Tone
This is my first smart phone that I have own. I have gotten used to having an LG that I was able to have not only a certain ringtone for when someone calls but a certain ringtone for when someone sends me a text. Is there an app that can help me out with this or not? If so is this a free app? or do I have to pay? if i have to pay is that a one time payment or monthly? if it is an app do i ahve to use the app to look at my messages or not( cause wouldnt that just use up my data which i dont ahve unlimited)
THanks you for the help for a new smart phone user - 02-13-2013, 03:59 AM #2
Re: Personalized Message Tone
Although there are many 'dialer' or phone apps for Android phones, they work similarly. When you edit a contact, you should see a way to change or set their ringtone, most often you will see it when you long-press on the contact name.
An app like Dialer One (which I use and recommend) or Group Contacts (which I haven't used) will let you assign a ringtone to a 'group' of numbers, so your friends, family, co-workers or poker buddies can each have their group's ringtone played. - 02-14-2013, 09:27 PM
Thread Author #3
- 02-14-2013, 10:33 PM #4
I use Glowfly, it will do this and its less than two dollars
sent via smoke signals - 02-17-2013, 09:55 PM
Thread Author #5
- 02-17-2013, 11:44 PM #6
The (free with ads) Handcent messaging app will let you customize a notification for anyone you have a history of sending a message with. Open Handcent, click their name in the list, in the upper right you'll see an icon of a face with a gear, that's settings. Click that and you'll see a choice for notifications, and can then set a ringtone for them there, as well as if it should vibrate or not, light the phone's LED or not, etc.
- 03-03-2013, 05:27 PM
Thread Author #7
Thanks I figured it out and it works great....only problem I have not is that i use ringtone for my text messages which i like cause they last longer and are more distanct only problem I have is when im right next to my phone i dont know how to silence it right away. On my LG phone i used to beable to hit the side button and it would stop the music before it woudl usally end.
text message tones
By seass in forum IntroductionsReplies: 0Last Post: 04-29-2012, 07:01 PM -
Text Message tone after new update
By panicprone77 in forum Verizon HTC ThunderboltReplies: 10Last Post: 07-11-2011, 05:27 PM -
Help with custom message tones
By cheekys00 in forum AT&T Inspire 4GReplies: 7Last Post: 03-30-2011, 03:57 PM -
Different text message tones...
By theoriginalseed in forum AT&T Inspire 4GReplies: 2Last Post: 03-30-2011, 08:31 AM -
How to set custom text message tones for contacts?
By chasescott66 in forum Motorola DroidReplies: 1Last Post: 11-30-2009, 10:52 PM
Reply
