So somehow yesterday my Nexus 7 disappeared from the Google Play Store. I've no idea how and I have no idea how to reconnect it. I'm just being told I don't have any devices.
Printable View
I've seen that issue on the Nexus 7 a few times, the play store just gets messed up.
Manage your apps, for Google Play Store and Google Play Services you should clear the cache and uninstall updates, then reboot the device, then wait. Play will automatically update and fix the issue.
Sent from my XT907 using Tapatalk 2
That it did. Very strange thing. But thanks!
if you clear google play service framework the device will dissapear temp for a while.Quote:
Originally Posted by ctt1wbw [Only registered and activated users can see links. Click Here To Register...]
it will come back after a while
