Results 1 to 6 of 6
    Default unfortunately, the process com.android.phone has stoped.` how to fix it?
  2. #2
    Default Re: unfortunately, the process com.android.phone has stoped.` how to fix it?
    If you use an app called "Facebook Contact Sync", or some other 3rd party contact syncing software by any chance: Some of those apps mess around with the contacts you have on your phone, have seen this happen on a Galaxy S3 before. For instance an unreadable birthday is synced and this makes the com.android.phone software crash...
  3. #3
    So, how do u fix the problem?
  4. #4
    Quote Originally Posted by Nibal View Post
  5. #5
    Seems like phone service (software not carrier service) going down and you would need to check lolcat to see what causeing it. If you desperate then do factory reset
  6. #6
    Thumbs up Re: unfortunately, the process com.android.phone has stoped.` how to fix it?
    Can not add contact
  1. the process com.android.phone has stopped unexpectedly error
    By Nana2tha5thPower in forum Samsung Galaxy S II
    Last Post: 02-07-2013, 05:42 AM
  2. Process com.android.phone has stopped?
    By adamMST in forum AT&T ATRIX
    Last Post: 06-14-2012, 12:02 PM
  3. Factory data reset: The process com.android.phone has stopped une
    By pshue in forum Software Development and Hacking
    Last Post: 12-01-2011, 01:15 AM
  4. Replies: 3
    Last Post: 04-18-2011, 12:31 AM
  5. Replies: 0
    Last Post: 01-13-2010, 11:58 AM
