Help choosing Custom ROM for tablet.
Hi there everyone.
I'm having a bit of a dilemma choosing a ROM to install on my tablet. I have a Kross M742 running Android 2.3.4 (Already Rooted thanks to Gingerbreak), and I'm having a hard time finding a ROM to use. I have heard of CynogenMod, but I see they are all specific (mostly) to models of phones/tablets.
So is there any specific one I should use for this tablet?
Re: Help choosing Custom ROM for tablet.
Quote:
Hi there everyone.
You're right that ROMs are device specific - a ROM made for one tablet will not work on a different tablet. Usually, the more popular a device, the more ROMs available for that device. As you seem to have a non-mainstream tablet, it might be difficult to find developer support for it.
I've found that out at least the hard way. There is no trace of Kross anywhere I've looked, so no official device support either. I just want to see if I can do any kind of upgrades or other Custom OS installs aside from different Launchers. I figured that it'd be safer to use the tablet to try on instead of my Samsung Galaxy S2X, just due to not wanting to brick my phone, and Samsung should be rolling out the Jellybean update to it within a month.
Is there any ROM that would be suggested to try out?
