Results 1 to 3 of 3
    Default Help choosing Custom ROM for tablet.
    Hi there everyone.
    I'm having a bit of a dilemma choosing a ROM to install on my tablet. I have a Kross M742 running Android 2.3.4 (Already Rooted thanks to Gingerbreak), and I'm having a hard time finding a ROM to use. I have heard of CynogenMod, but I see they are all specific (mostly) to models of phones/tablets.
    So is there any specific one I should use for this tablet?
  2. #2
    ragnarokx's Avatar
    Posts
    Global Posts
    8,669 Global Posts
    ROM
    SlimBean, LiquidSmooth
    Default Re: Help choosing Custom ROM for tablet.
    Quote Originally Posted by RedMageX View Post
    Hi there everyone.
    You're right that ROMs are device specific - a ROM made for one tablet will not work on a different tablet. Usually, the more popular a device, the more ROMs available for that device. As you seem to have a non-mainstream tablet, it might be difficult to find developer support for it.
    I've found that out at least the hard way. There is no trace of Kross anywhere I've looked, so no official device support either. I just want to see if I can do any kind of upgrades or other Custom OS installs aside from different Launchers. I figured that it'd be safer to use the tablet to try on instead of my Samsung Galaxy S2X, just due to not wanting to brick my phone, and Samsung should be rolling out the Jellybean update to it within a month.
    Is there any ROM that would be suggested to try out?
  1. Help choosing a rom for my needs
    By Redchigh in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 09-28-2012, 12:32 PM
  2. Help...How to check correct custom rom for every android devices?
    By ThetKo in forum Software Development and Hacking
    Last Post: 06-04-2011, 02:43 PM
  3. Need help: rooted, custom ROMs = spontaneous reboots
    By rockdawg in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-15-2010, 08:45 AM
  4. Replies: 1
    Last Post: 07-07-2010, 12:57 PM
  5. What's Considered the Best Custom ROM for the Droid?
    By eregitano in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 02-24-2010, 11:14 AM
