1. bevhoward's Avatar
    nexus7 running 4.2.2 and using "filemanager" to access the file system
    I've uploaded a test file from windows7 using MTP to the "Nexus 7/Internal Storage/Music" folder
    Then, using filemanager on the nexus 7, I can see this folder under several different paths... for example;
    /mnt/sdcard
    /sdcard
    /storage/sdcard0
    /storage/emulated/0
    /storage/emulated/legacy
    (there may be more...)
    1. Can someone point me to a site to help me understand this a bit better?
    2. When accessing the file system, which of the above should I use to manually manage files?
    Thanks in advance,
    Beverly Howard
    02-17-2013 02:36 PM
  2. Lanhoj's Avatar
    Can't help explaining it, but I use "/storage/emulated/0" which I think is the default.
    02-17-2013 02:56 PM
  3. bevhoward's Avatar
    Thanks for the response... appreciated,
    Beverly Howard
    02-17-2013 03:23 PM
  1. screen broken, need help recovering files/settings
    By duedermont in forum AT&T ATRIX
    Last Post: 04-17-2013, 07:38 AM
  2. Need Help Understanding File System
    By Davidoo in forum Verizon Galaxy S III
    Last Post: 07-21-2012, 04:12 PM
  3. I need help understanding data plans
    By laurelt32 in forum T-Mobile
    Last Post: 10-05-2011, 02:52 PM
  4. Really need help understanding contacts!
    By radtech in forum General Help and How To
    Last Post: 06-10-2011, 11:24 AM
  5. exchange and calendar...need help understanding
    By andinc4 in forum Verizon Droid Incredible
    Last Post: 05-07-2010, 05:08 PM
