Results 1 to 3 of 3
    Default help with phone
    I have an Huawei ascend I seen in my storage that there is a software update ur able to click what's this for? IM wanting to find out info about this before I click on it pls help me out I don't wanna mess up my phone
    Sent from my H866C using Android Central Forums
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: help with phone
    Does it say what the update number is? Generally, updates for to upgrade the phone to a new Android OS or security/house keeping updates. If you can find out what the update number is before you download check the forums and see what the update offers. In most cases, you are advised to update since a security fix may be included.
    When I click on the software upgrade it says upgrade via sd card what does this upgrade mean?
  1. Help with phone update
    By innovationplus in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 01-30-2012, 06:51 PM
  2. Help with phone
    By Sdude1200 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 08-25-2011, 08:49 PM
  3. Need some Help with phone updates
    By SkyHeroMZ in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 08-18-2011, 01:31 AM
  4. I need some help with phone signal....
    By bamaatheart in forum General Help and How To
    Last Post: 03-06-2011, 08:12 AM
  5. Need some Help with phone updates
    By in forum Verizon HTC Thunderbolt
    Last Post: 12-31-1969, 07:00 PM
