Results 1 to 4 of 4
    Default PC won't recognise Nexus 4
    My work desktop running XP won't recognise my Nexus 4 when connected via USB. Have looked through various threads to try and find the answer and subsequently tried different USB ports, different cables etc but still comes up with the "found new hardware" wizard when plugged in. The cable and phone work when plugged into my laptop running Windows 7 so guess the problem must be with the desktop setup. The phone does charge when plugged into the desktop but the device is not recognised and I therefore do not have the option to explore. Can anyone help?
  2. #2
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,819 Global Posts
    ROM
    Homebrewed
    Default Re: PC won't recognise Nexus 4
    Win XP requires an MTP driver. That page will fix you up.
    Default
    Quote Originally Posted by Jerry Hildenbrand View Post
    Thanks for the suggestion - I'll give it a go tomorrow and see if it does the trick!
    OK - downloaded the MTP Porting Kit from Microsoft but still ahve the same problem. Restarted computer etc but when I plug the phone into the USB port it stillcomes up with the "Found New Hardware" wizard. Any other suggestions?
  1. How do I get my PC to recognize the Nexus as a drive?
    By bbhybridchris in forum Verizon Galaxy Nexus
    Last Post: 12-29-2011, 07:47 PM
  2. Music From PC Won't Sync
    By sdweller in forum Verizon Galaxy Nexus
    Last Post: 12-20-2011, 08:00 PM
  3. PC won't see phone
    By lws.jazz in forum Sprint Nexus S 4G
    Last Post: 12-12-2011, 08:30 PM
  4. PC Won't Recognize SD Card
    By mylasthope in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 06-12-2011, 12:46 PM
  5. Problems- PC won't access pfone via USB
    By Broon in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 03-13-2011, 10:36 PM
