Results 1 to 7 of 7
    Default LG-E400 wifi will not turn on.
    Hi,
    I am totally new to Android, having bought an LG-E400 one week ago. The phone is running v2.3.6. It is running on Spain's tuenti network and up until two days ago it was running fine in every way. The problem now is that it will not allow 'turn on' the wifi, let alone connect or use it.
    When I check the 'Turn on Wi-Fi' box in Settings>Wireless & networks it tells me that it is turning on, and on occasion tells me that it is turned on, but invariably it 'turns off' within 10 seconds or less. When I turn on wifi using the icon int he pull down menu it likewise changes colour to signify that it is on, but turns off of its own accord within a few seconds. The wifi had worked perfectly until a few days ago, and nothing has changed since that time to the best of my knowledge. It is a new phone, has been used carefully, and there have been no other issues with it.
    I am feeling very frustrated and would appreciate any help or advice. My apologies if I have posted in the wrong forum, or if there is a glaringly obvious solution that I'm not seeing.
    Thanks,
    Conor
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Default Re: LG-E400 wifi will not turn on.
    Quote Originally Posted by Conor McGuinness View Post
    Hi,
    Thanks,
    Conor
    Try rebooting your router
  3. #3
    And also try rebooting your phone.
    Sent from my DROID RAZR using Android Central Forums
    Thanks for your replies.
    droidXcon:
    Unfortunately I have no control over the router as I am working in a residential institution. My colleagues have not experienced any problems with the wifi here over the last few day, so I'm assuming its an issue with my phone. Its not a question of the wifi not working, the problem is that my phone will not turn wifi on, or at least for any longer than ten seconds.
    B. Diddy:
    I can't overemphasise the fact that I am a beginner wwhen it comes to both android and smart phones more generally. Is reboot the same as restart? How do I reboot my device? Is there some kind of connection issues wizard I can use to search for problems?
    Thanks again for your help,
  5. #5
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    Maybe it's an app your installed recently. You can try backing out some apps in hopes that something you downloaded is messing with the phone. If not, since it's a new phone, might want to just do a factory reset and see if that fixes the problem. If it does fix the problem, slowly tweak the phone and add back apps. That way if the issue occurs again your can more easily identify it. If that doesn't work, you should get it replaced.
  6. #6
    What I mean by reboot is simply to power it down fully and then power it up again. Hold the power button down until the option to turn off the phone comes up, and select it. After the phone completely turns off, hold the power button down again until it starts up again. Try doing this before considering the full factory reset (which you can do by going to Settings/Backup & reset and selecting Factory Data Reset, which will completely get rid of all of the apps, data, photos, and music on your phone).
  7. #7
    Try setting "Never" in sleep policy option in the wifi advanced settings.
  1. Xoom will not turn on
    By FireGuy303 in forum Motorola Xoom
    Last Post: 10-31-2013, 09:17 AM
  2. Droid's Screen Will Not Turn On??
    By GAlex067 in forum Motorola Droid
    Last Post: 01-19-2011, 09:22 AM
  3. blackflip will not turn on!!!!!!1
    By bigheadtony6 in forum Motorola Backflip
    Last Post: 11-04-2010, 05:02 PM
  4. Inc will not turn on, no charge light
    By monkeymisfit in forum Verizon Droid Incredible
    Last Post: 09-23-2010, 11:29 PM
  5. Phone will not turn on
    By kvaughan#AC in forum Verizon Fascinate
    Last Post: 09-14-2010, 09:39 AM
