1. ahawkua's Avatar
    I am just wondering if swipe keyboard uses battery? My phone came with it already. I am running android 2.3.6
    02-24-2013 08:24 PM
  2. Mooncatt's Avatar
    It probably does since it has to interpret what you're trying to type instead of putting single letters up. Would it cause a noticeable drop in battery life? Doubtful. I don't think it ever shows up on my battery use meter, and never seen any threads about the issue.
    02-25-2013 01:01 AM
  3. Paul627g's Avatar
    Agreed. The small amount of battery Swype is using isn't even worth fussing over compared to all the other known battery eating apps.
    For a better 'easier' keyboard that slight hit in battery is worth it.
    02-25-2013 01:06 AM
  1. Does android app pops use more battery than stock messaging app
    By ahawkua in forum General Help and How To
    Last Post: 02-20-2013, 10:49 PM
  2. Does chomp sms use more battery than stock
    By ahawkua in forum Android Apps
    Last Post: 02-20-2013, 07:37 PM
  3. does adw launcher use more battery?
    Last Post: 12-19-2012, 08:51 AM
  4. does adw launcher use more battery?
    By ahawkua in forum Resistance
    Last Post: 12-18-2012, 01:06 AM
  5. does handcent sms use more battery than stock messaging app?
    Last Post: 12-13-2012, 08:52 PM
