Results 1 to 2 of 2
    Lastnv's Avatar
    Posts
    Global Posts
    77 Global Posts
    Default Scale down screen resolution?
    Is there a way to scale down or zoom out in an app so the screen is smaller so I can achieve a better resolution?
    I specifically want to use it for MyBoy since the app blows up the size on my Note 2 and it doesnt have as good clarity if I could make the screen smaller.
    please and thanks
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
  2. Thread Author  Thread Author    #2
    Lastnv's Avatar
    Posts
    Global Posts
    77 Global Posts
    Default Re: Scale down screen resolution?
    bump
  1. Power controls on the slide down screen
    By rustypixel in forum Verizon Fascinate
    Last Post: 02-20-2011, 05:42 PM
  2. How to modify screen resolution?
    By hidavy in forum General Help and How To
    Last Post: 01-30-2011, 06:27 AM
  3. screen resolution
    By Grizzly420 in forum Verizon HTC Thunderbolt
    Last Post: 01-12-2011, 05:28 PM
  4. Poor screen resolution
    By drfrank in forum Sprint Epic 4G
    Last Post: 09-11-2010, 02:00 AM
  5. Screen Resolution
    By AWDmonster in forum Motorola Droid 2
    Last Post: 08-10-2010, 10:34 AM
