My phone will say its not charging when i have the charger plugged in. When its not plugged in, it says its charging. Its only been doing this for and hour or two.
It may be a faulty USB port on the phone. Could maybe try a new USB cable, which is usually the cause of being plugged in but not charging. Not sure if that's the case this time since it also reports charging when not plugged in.
