Results 1 to 5 of 5
    JOEbygodBUC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Need help, phone is being weird
    My phone will say its not charging when i have the charger plugged in. When its not plugged in, it says its charging. Its only been doing this for and hour or two.
  2. #2
    gotta have it android's Avatar
    Posts
    Global Posts
    341 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Need help, phone is being weird
    Are you rooted and are you using a custom ROM?
    Quote Originally Posted by JOEbygodBUC View Post
  3. #3
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It may be a faulty USB port on the phone. Could maybe try a new USB cable, which is usually the cause of being plugged in but not charging. Not sure if that's the case this time since it also reports charging when not plugged in.
  4. #4
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,827 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mooncatt View Post
    Going off of what Mooncatt said, check to make sure there's no debris among the metal pins inside the microUSB port. If you can find one of those compressed air dusters, they work wonders for clearing ports.
  5. #5
    Ara98's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Factory reset the device.
  1. Need help phone is dying
    By imnotajedi in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 07-05-2012, 05:03 PM
  2. Need help.. phone is confused?!
    By smoroeace in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 10-08-2011, 01:10 PM
  3. I Need Help phone is tripping!
    By Beatzbyreefah in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 07-11-2011, 09:47 AM
  4. Need Help Phone dead after running Unrevoke
    By xvflutop in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 11-19-2010, 09:28 AM
  5. Need help phone freezing 2.2
    By Umass021 in forum Motorola Droid
    Last Post: 08-05-2010, 03:01 PM
