1. ahawkua's Avatar
    I am wondering if using vibrate on keypress uses battery?
    02-26-2013 09:28 PM
  2. Patrick Schroedl's Avatar
    Vibration in our phones is caused, essentially, by a small motor or similar component that is 'shaking'. It takes battery power to do this. However, unless you are typing an excessive amount on your device, the impact on battery life should be negligible.
    02-26-2013 09:37 PM
  3. pontiac005's Avatar
    Yes and so does the vibrate ringer.
    02-26-2013 09:41 PM
  4. still1's Avatar
    technically Yes, but very little.
    02-26-2013 09:42 PM
  1. Will vibrate on keypress use battery?
    By ahawkua in forum General Help and How To
    Last Post: 12-27-2013, 08:47 PM
  2. Replies: 2
    Last Post: 12-19-2012, 01:42 PM
  3. Google Music vs Music on memory card - Battery use?
    By PaulQ in forum Verizon HTC Rezound
    Last Post: 04-09-2012, 04:03 AM
  4. How to charge battery properly on 1st use & is an adapter okay?
    By Alazarin in forum Samsung Galaxy S II
    Last Post: 11-03-2011, 11:25 AM
  5. Does removing unnecessary networks free up battery use?
    By spooksmcgee in forum General Help and How To
    Last Post: 07-31-2010, 04:27 AM
