I am seeing 3.31Gb of space for pictures and videos under System Settings- Storage - Device Memory, but I thought I had changed the default location for pictures and videos. Where is it getting this number?
Printable View
That depends...did you change the location of pictures that will be saved from now on to your SD card...or did you actually move all of the files...?
If you didn't move all of your files, they will still be counted there under your device memory...
