Results 1 to 4 of 4
    Lean4838's Avatar
    Posts
    Global Posts
    30 Global Posts
    Default Stuck at "Upgrading Software", hard reset does not work, and cannot be recognized by PC!
    Hi all,
    I am new to this forums and desperately in need of help! Sorry if I am posting in the wrong thread.
    I currently have a problem with my Sky Vega phone. I was updating it while it was connected to my PC but unfortunately the update did not finish properly.
    Now it is stuck at "Upgrading Software". I have tried the "Volume Down + Power Button" trick and other variants but I can't seem to access recovery mode / download mode. It keeps booting at "Upgrading Software". I also tried removing and reinstalling the battery.
    Additionally, now my PC doesn't even seem to detect it! So I am really currently at a loss of what I am supposed to do and how to fix my phone properly.
    Can anyone make a suggestion?
    Thank you everyone!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Stuck at "Upgrading Software", hard reset does not work, and cannot be recognized by PC!
    Do you know the exact combination to get to the recovery menu for your phone? If not, find it, just to make sure you are doing it correctly.
    If that doesn't work, try contacting the manufacturer. Or, if the phone is still under warranty, just get it replaced.
    Lean4838's Avatar
    Posts
    Global Posts
    30 Global Posts
    Quote Originally Posted by Devinator View Post
    Thanks! I did find something (Volume Down + Search button + Power button) however it still did not work.
    Is there something like a button inside the device that maybe I can push with a needle or something? Do some devices include that?
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Doubtful. Your best bet is probably to just contact the manufacturer with your issue. If you were just doing an update, then, they should be able to help you, or replace it if necessary (as long as you are under warranty).
  1. SOLVED: ICS Upgrade - Factory Reset Does Not Fix Battery Drain
    By nim6us in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 05-17-2013, 10:49 AM
  2. Replies: 25
    Last Post: 05-16-2013, 01:32 PM
  3. Hard reset, no data plan, will wifi be configurable?
    By sydseale in forum General Help and How To
    Last Post: 05-06-2011, 08:32 AM
  4. What software does not work with OTA update?
    By mrmanishs in forum AT&T Captivate
    Last Post: 09-23-2010, 08:53 PM
  5. To hard reset or not to hard reset?
    By ethan in forum Motorola Droid
    Last Post: 04-02-2010, 05:24 PM
