Results 1 to 8 of 8
    Delenot's Avatar
    Posts
    Global Posts
    52 Global Posts
    Default Where to purchase phone?
    Would anyone please suggest places I can purchase an HTC Dinc 2? I would prefer unused. For use on verizon. My phone fried itself, literally I think. It started making a garbled static noise and now won't do anything. Both the front and rear facing camera appear to be internally foggy, though I don't remember the phone getting wet. Any suggestions would be great! Thanks in advance.
  2. #2
    Greg C's Avatar
    Posts
    Global Posts
    688 Global Posts
    ROM
    Stock Jellybean 4.2.2
    Default Re: Where to purchase phone?
    Quote Originally Posted by Delenot View Post
    If my post helped you out...please be kind and hit the "THANKS BUTTON."
    Thanked by:
  3. #3
    Greg C's Avatar
    Posts
    Global Posts
    688 Global Posts
    ROM
  4. #4
    Greg C's Avatar
    Posts
    Global Posts
    688 Global Posts
    ROM
  5. #5
    Greg C's Avatar
    Posts
    Global Posts
    688 Global Posts
    ROM
    Delenot's Avatar
    Posts
    Global Posts
    52 Global Posts
    Thank you for the suggestions.
    This has likely been covered somewhere in these forums. What should I look for to try to find a safe sale? I have heard you need to check the ESN number, or something like that. SHould the item listing show that number? And is it as easy as calling your carrier to check its condition?
  7. #7
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    If you buy from Ebay be sure to check the sellers rating and ask if the esn is clean. I have purchased phones on ebay before without a problem. You might also want to check Swappa.com from used devices. Craigslist is the other option if you want to meet the person at a store and verify its clean to activate.
    Sent from my GT-P7510 using Tapatalk 2
    Thanked by:
  8. Thread Author  Thread Author    #8
    Delenot's Avatar
    Posts
    Global Posts
    52 Global Posts
    Thank you everyone. The help is appreciated.
  1. Where to purchase new phone
    By adamcohen79 in forum Sprint
    Last Post: 05-29-2012, 09:27 AM
  2. Where to purchase Evo 3D?
    By carp00r85 in forum HTC EVO 3D
    Last Post: 06-14-2011, 05:39 PM
  3. where to purchase?
    By Irishluck002 in forum AT&T ATRIX
    Last Post: 03-11-2011, 03:42 PM
  4. where to purchase?
    By angelocondulle in forum HTC EVO 4G
    Last Post: 03-02-2011, 04:37 PM
  5. HTC OEM 1500mah battery for incredible, where to purchase?
    By trmoney24 in forum Incredible Accessories
    Last Post: 10-01-2010, 10:01 AM
