Results 1 to 2 of 2
    bwrichardson17's Avatar
    Junior Member
    Posts
    Default Can kybd be customized?
    I would like to add the comma to the ABC screen without having to shift or hold down the "n" button. Is that possible? Thanks Bruce Richardson
  2. #2
    Greg C's Avatar
    Posts
    Global Posts
    688 Global Posts
    ROM
    Stock Jellybean 4.2.2
    Default Re: Can kybd be customized?
    Quote Originally Posted by bwrichardson17 View Post
    You would need to use a third party keyboard such as Swiftkey which is among.... the best if not the best.... third party keyboards.
    If my post helped you out...please be kind and hit the "THANKS BUTTON."
  1. Can "SyncService" be force closed and perm stopped?
    By sniffs in forum Android Applications
    Last Post: 05-26-2010, 10:08 AM
  2. EVO bought in store only or can it be telesales?
    By dfine1966 in forum HTC EVO 4G
    Last Post: 05-13-2010, 01:43 PM
  3. The screen outside CAN'T be this bad for everyone using an N1.
    By RBasil in forum Google / HTC Nexus One
    Last Post: 04-29-2010, 09:13 AM
  4. Can this be done?!
    By stefanl in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 04-25-2010, 09:52 PM
  5. Calendar sounds: Can they be turned off?
    By andrewstevenh in forum HTC Hero
    Last Post: 04-22-2010, 10:19 AM
