Results 1 to 4 of 4
- 03-08-2013, 01:37 PM
Thread Author #1
Can't Mount SD Card
I got my HTC Desire C last month, and i didn't have an SD card, so I got a second hand one from my mum's friend. It started off by mountinunmountinrandomly, but now when I try to mount it, it immediately tells me that the sd card is safe to remove. How can u I get the card to mount? I've tried.erasing it and restarting my phone, but it still doesn't work.
Any answer is much appreciated! - 03-08-2013, 02:09 PM #2
Re: Can't Mount SD Card
SD cards can go bad, or can be faulty. Have you tried a different card?
Sent from my DROID RAZR using Android Central Forums - 03-09-2013, 02:20 AM
Thread Author #3
- 03-09-2013, 02:41 AM #4
Try your current SD card in your computer. If your computer can't read it, then you know it's bad. But even if it does work in your computer, it could still be glitchy and not work correctly in the phone.
Can't mount SD card after update to 2.2.2
By mk3 in forum Samsung TransformReplies: 0Last Post: 08-15-2011, 12:25 AM -
Can't mount sd card after clockwork flash
By fults in forum Verizon FascinateReplies: 0Last Post: 08-15-2011, 12:17 AM -
Clockwork can't mount sd card
By JDowling in forum ASUS EeePad TransformerReplies: 3Last Post: 06-17-2011, 11:56 AM -
Can't mount SD card after Root
By delucx in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 22Last Post: 01-22-2011, 11:38 PM -
can't mount sd card
By linwiz in forum Verizon Droid IncredibleReplies: 5Last Post: 12-10-2010, 08:19 PM
Reply
