My Droid Incredible froze and is stuck on the colorful X logo after installing Jellybean-inc-RC4.
I have tried to take out the battery and restart again to no luck.
I wiped data/factory reset - wipe cache partition - wipe Dalvik cache - format system.
I am running CWM 2.5.0.1. I installed zip Jellybean-inc-RC4 from SD Card - then gapps-jb42-20121227TINY-signed. Also I can't enable USB debugging to flash. Thanks
