Results 1 to 20 of 20
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    Poor battery life. It’s one of the most discussed topics in the forums. Is it result of defective hardware, the OS, network connectivity, Sense UI (on HTC devices), or other 3rd party apps? Instinctively (particularly if you’re new to the world of Smartphone’s) the rapid depletion in battery life - even with light to moderate usage - might lead you to believe that your phone has major problems in this area.
    I’m of the belief that there are always areas of improvements in how each of the above variables affects battery life. For example, there could be future ROM update that enhances OS efficiency, task management, or the efficiencies in manufactures (called bloatware by some/but loved by others) in additional apps or skins. Another culprit is that battery technology and capacity have not evolved as rapidly as the power and functionality in today's powerful Smartphone’s.
    Cars are very similar. For example, an Audi S4 has a powerful 352HP V8 engine, which is much faster than your average commuter car. However, the 352HP engine comes at a price. It burns through gas really quickly, and like the EVO requires a great deal of energy to live up to its potential. The S4’s source of energy is stored in a 14-gallon gas tank in the rear of the car. If I push the car to it’s full potential – and gets approximately 10 miles per gallon. Contrast that to an A4 with a 4 cylinder engine averages twice the number of miles per gallon, and has the same size gas tank. Smartphone’s aren’t any different. For example, the battery in the HTC Ozone and the battery in the EVO are exactly the same in terms of capacity. They both provide 1500 mAh’s of energy. However there are distinct differences in screen size, processor power, network types, features, etc… Having used both, I can tell you the battery life was the least of my complaints on the Ozone.
    That said here are some of the most common items (based on my unscientific tests of various Smartphone’s) that are the highest consumers of battery life. Most are manageable from a user perspective, some are not. I’ve left out the most obvious one of all – extended voice call activity. Just remember there is a trade off between performance/features and the amount of power you’re willing to devote to each.
    - 4G if available (worse than 3G) and 3G connectivity/activity by streaming audio/video apps, web browsing, instant messaging apps, and apps that poll the network at regular intervals for updates (Facebook, RSS readers, Friendstream, etc).
    3G: See those little white arrows at the top of your screen? When they are light grey in color, network utilization is zero. Contrary, when they are solid white, network usage is occurring. If they are constantly white (as they would be when streaming radio for example) battery consumption is at it’s highest.
    4G (applicable to Sprint 4G phones): The first day I got my hands on an EVO, I immediately turned on the 4G radio. After all, this was one of the EVO’s main selling points. 3 hours after a full charge, my battery was toast, and I hadn’t even browsed the web yet. I was really disappointed that I was required to manage this radio and only use it when absolutely necessary, but that’s the reality of 4G technology.
    - Bright backlight settings: Phone's like the EVO and Droid X have massive 4.3” LCD screens. Regardless of backlight settings, the screen is still a major power consumer. Having said that, slight changes in backlight settings can make a dramatic difference in battery consumption. I would recommend avoiding the very brightest setting. My preferred setting is to let Android manage screen brightness, while others have manually enforced a constant low to medium brightness level. The latter will have the greatest positive affect on battery life.
    - High CPU, backlight, and network usage by graphics intensive and/or poorly written applications: Graphics intensive programs often consume large amounts of CPU power and RAM, which translates into high battery consumption. Combine this with a network intensive streaming media application (e.g., vCast, Sprint TV, Pandora, or similar apps); your smartphone of choice is sucking the life out its battery at an extremely high rate. Applications that were not designed for your particular smartphone or are buggy in nature might causing the CPU to work excessively hard. If your phone is warm to the touch and running particularly slow, there’s a good chance a 3rd party app is the culprit.
    - Bluetooth: Bluetooth sucks down power. I’ve experienced this on every phone I’ve ever used. Enabling bluetooth, within settings or via a bluetooth toggle widget, isn't necessarily a battery hog. It's the active use of bluetooth (for example on a call, or connected to a computer) that begins to drain bluetooth at a higher rate
    - GPS: Like Bluetooth, it consume large amounts of energy while updating coordinates and communicating with satellites orbiting the earth. Combined with turn-by-turn directions and an always-on backlight, in order to see the maps guiding your way, you’re pushing battery consumption to the limits. I often read posts from people who are using their smartphone as a full time GPS device in the car. One common complaint from these users is that USB chargers are only maintaining the current battery level – or worse – when GPS is in use. Since most phones limit USB host connections to 500mAh of power input, this is a good indicator of how much GPS consumes. In other words, 500mAh of continuous power to the phone is not enough to charge and take advantage of GPS/turn by turn directions at the same time. When choosing a car charger, try to choose one that meeds the minimum mAh output of the stock OEM charger. This will ensure the phone is receiving enough power to both use these applications and charger at the same time.
    - Signal Strength: Whether 3G, 4G, or WiFi, week signal strength can affect battery life.
    - CPU/Memory: I often read posts from members who have most of the above features disabled. Yet they still report warm to the touch phones and unusually poor battery life (3-4 hours per charge). In my experience, this is usually caused by 3rd party CPU intensive applications. Many people reach for the nearest task manager. Others can’t imagine which application they’ve installed that would cause such an issue. Regardless, if you reach to other forum members for assistance, please provide the following information that varies from the out of box configuration of the phone:
    o Task managers in use (I believe these cause more harm than good – but there’s a totally different sticky devoted to that).
    o A list of all 3rd party applications (including battery percentage widgets & instant messaging applications)
    o Update frequency settings for each application in settings > accounts & sync.
    o Detailed information from settings > about phone > battery use
    o GTalk auto sign in settings
    o 4G use (if applicable)
    o 3G data arrow activity (frequent solid white arrows?)
    o Email configuration (update frequency for Exchange, IMAP, Gmail, POP)
    o Type of charger being used (OEM vs. 3rd party) & input/output specs.
    o Widgets in use.
    And please read the task manager sticky for important information about the use of these programs.
    The best but least practical solution to battery consumption is to disable every single feature possible that your phone has to offer. Is this a practical solution? Probably not. My recommendation is to find a balance that works best for you and come to the terms that the attributes that make your smartphone the best converged device available requires, will demand increased energy & negatively impact battery life. This amount of energy available in a fully charged OEM battery is specified on the back of your battery. Look for extended OEM batteries to extend the use of your battery before needing to plug it in again. I also recommend the combination of a second battery and battery only charger, to ensure a spare is always at hand.
    I hope you found this information helpful, and if you have any other tips, please post them below.
  2. #2
    Default
    This for me, really helpful.
    Thank you !!
  3. #3
    messyo's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default
    it's helpful ,now i know what to do with the battery.
  4. #4
    Default
    Thanks!
  5. #5
    Default
    in Cars are very similar. For example, an Audi S4 has a powerful 352HP V8 engine, which is much faster than your average commuter car. However, the 352HP engine comes at a price.
  6. #6
    alexsamson's Avatar
    Posts
    Global Posts
    5 Global Posts
    Default
    This is a massive issue for some devices. After a few months with an HTC desire, here are my thoughts on the subject, plus a potential solutions:
    http://computersight.com/computers/the-great-htc-desire-battery-debate/
    The best solution I have found:
    http://computersight.com/computers/htc-desire-green-power-app-review/
  7. #7
    buckeye_jeff's Avatar
    Posts
    Carrier
    Wicked Sensations v1.3
    Default
    Some of this is common sense and some of it I hadn't thought about. Thanks!
  8. #8
    Default
    If you follow these guidelines, how long should your battery last? I recently got a Droid X, and the battery life has been around 1 full day. I thought this was pretty terrible considering my last phone could last around half a week. But after seeing that some phones only last 3-4 hours, I don't know lol.
  9. #9
    sefco9's Avatar
    Posts
    Carrier
    2.1-Update1 Esclair2.6.29
    Default
    Helpful post...it’s really common sense
  10. #10
    Default
    I have been adding the tips from all the battery life threads into the Getting Started with Android section on Extending Battery Life. In particular, Juicedefender and UltimateJuice seem to be the key because they turn things on and off automatically as you need them.
  11. #11
    Spudski's Avatar
    Posts
    Carrier
    CM7 Nightly Builds
    Default
    You basically explained my whole life. Thanks a bunch
  12. #12
    Default Battery Life and Car Charger
    I have the EVO and use my Igo car charger to 'try' and power it while I'm driving. It seems to burn more battery on the car charger, what's up with that?
  13. #13
    Default
    thanks, helped a lot
  14. #14
    Default
    what is recomended to increase battery life?
  15. #15
    Default Need a Bettery Battery Backup for Android Device? Try This!
    For those that don't win one of the neat backups from AC, here is a method that I have been using. It is based on the Tek4 Ryobi kit from Home Depot that I was lucky to find on sale a year ago for $50. Yes, all 6 items were included in the box plus 2 of the 6wh (1500 mahr) LI-ION rechargable batteries and the charger. If you look closely, a green led on the module lights when phone is charging and the indicator on the EVO also turns on. It has a lot of adapters, but the micro USB is used for most phones today. I have used this system to record 7.5 GB of RC Sailing video at a remote location with battery to spare. I think additional batteries are about $13.
    The 2nd photo shows the phone up close to show the wallpaper. I am an avid fan of the HTC scenes and have about a dozen including ANDROID, GAMES, PEOPLE, TECHNOLOGY, FINANCIAL, SHOPPING, etc... Thus, it is important to know which scene you are in as it requires you to save with EXACT same scene name everytime you change something in a sceen such as move, add or delete an Icon. If you look closely, you will see the word "ANDROID" repeated in the background wallpaper. It took me about 2 months to really understand the scenes system. The backgrounds were created using Docs to Go Word application. If this is helpful, click on the "Thanks".
  16. #16
    Fnordish's Avatar
    Posts
    Carrier
    Vanilla HTC 2.2
    Default
    It's nice to know I'm on the right track then.
    I've found it's useful to have a task killer handy (not set to auto) for when some random app decides to have a feast on my battery.
    It may not be elegant, but crashing everything has proved effective when I can't figure out which app is chewing down the cycles.
  17. #17
    Default
    Thanks for the info appreciate it
  18. #18
    Default
    Thanks for the tip. had my incredible for a couple days and I'm burning through my battery. Now I know where to start looking.
  19. #19
    Default
    yeah...thanks for the info too...helpful
  20. #20
    Default
    Okay, well I figure it would be pointless to create another battery thread, so I'm gonna ask my question here.
    I've had a MyTouch 4g for less than a week, and to be clear, it's my first android phone. I've done my share of googling to find out how to best preserve the battery. Now I just have some final questions.
    1. Yesterday, I experimented with not having the mobile network on, unless I needed to check my email, update my twitter, foursquare, or check in to answer my opponent on Words. Also, I was using my phone as an mp3 player, so I probably logged about an hour of music as well. Battery life was about 70% by 9 pm. I was pleased, but then something went wrong. I had my mobile network off and everything...by the time I was ready to go to bed by 1 am, battery life was down to 35%. I honestly have no idea what the huge drop off was to, because I was running it the same I was during the day. Mobile network off. GPS off. Bluetooth off. No live wallpaper. Etc.
    So what gives?
    2. This is day 2 of not having my mobile network on, and I noticed that my battery will stay at 100% for the longest time...using it actively once again for music, foursquare for a total of 30 minutes or so. However, before I napped around 4 (unplugged since 10), I decided to use it once more to check up on some stuff. Battery life was at 98%, and by the time I got done with it (5 minutes later), it was at 94%. Turned off mobile network and everything, sleep, and now battery life is still at 93% 3 hours later. It seems like it's conserving itself heavily, but the moment I start using it, battery just drops like no other.
    3. Can I get away with running 3G all day? I'm going to experiment with it, but no point if I can get a straight up answer.
    So yeah, these are my 3 questions. I'll probably repost this somewhere else if I don't get an answer down the road.
