1. Stickeyjam's Avatar
    I recently got a Nexus 4 after spending the last 5 years or more using an old Sony Ericcson phone.
    Today I went to add my phone numbers into my new N4 and it keeps asking me to add them to either my Google or Hotmail (I setup e-mail already) account. Why? I don't want to sync them, I just want to have them there on my phone. I've exported my entire phonebook as a CSV and VCF file on my PC, I but I really cannot find how to import without it also syncing with Google or Hotmail.
    It seems a bit silly to force this, any help?
    03-16-2013 07:03 PM
  2. B. Diddy's Avatar
    When you try to add a contact, can you select "Phone" as an account option? For example, on my Razr Maxx, if I try to add a contact, the edit contact screen has my Google account at the top. If I tap it, it allows me to select between my Google account and Phone (which on the Maxx is Backup Assistant, Verizon's version of contact backups). If I were to select Phone, then the contact would only be local and not synced with Google. If I activated Backup Assistant, it would be backed up to Verizon, but I never activate it.
    03-16-2013 07:08 PM
  3. Stickeyjam's Avatar
    Unfortunately no. I click "Import/Export" and select to import from storage. It then says "Create contact under account" and lists both my Google and Hotmail accounts, nothing else. If I touch out of the selection it just takes me back to the import/export screen, it's forcing me to pick either.
    03-16-2013 07:14 PM
  4. gone down south's Avatar
    AFAIK, there is no local contact storage on the N4,they're all associated with an account.
    03-16-2013 08:29 PM
  1. Adding contacts
    By seabeeluvr in forum Verizon HTC Thunderbolt
    Last Post: 03-25-2011, 07:41 AM
  2. Added contact goes to top
    By billfisher1 in forum Motorola Droid X
    Last Post: 02-16-2011, 04:43 PM
  3. Newly Added Contacts Not Showing Up In List ?
    By going_home in forum HTC myTouch 4G
    Last Post: 01-07-2011, 01:35 PM
  4. force close when adding contacts
    By EvoOWNSu in forum HTC EVO 4G
    Last Post: 09-21-2010, 10:47 AM
  5. Facebook sync added contacts I don't want
    By joshr in forum HTC Droid Eris
    Last Post: 05-19-2010, 12:24 PM
