Help me please !! Samsung S3 mini
I've tried to root my samsung galaxy S3 mini today it was completed but now it wont start up. It stays at the Samsung Galaxy S 3 mini screen.
Also i tried to connect it again with my pc but my pc says that there isnt a device connect. So i cant reboot it what should i do help me please.
Nordin Graulus
Re: Help me please !! Samsung S3 mini
im not a samsung owner but you should try booting into recovery and then connecting it to the computer, this could help. it sounds like you have a softbrick so your best bet would probably either be Odin or downloading the stock RUU and Restoring your phone back to factory settings. sorry this is all the help i can offer im more of a HTC Guy so my work on Samsungs is limitied.
Listen very closely.
Well, first of all I'm shocked that you bricked it on a root but anyway....
This is an easy fix do not worry.
Download "Odin" do q Google search for it you'll find it.
Then do a Google search for something like "galaxy's s3 mini stock sbf ROM" what you are looking for is a .sbf file of the stock ROM on your phone. You will find one somewhere. I will get on my computer I'm a little and I can find some links to this stuff
Download the Samsung kies drivers.
Then, enter download mode on your phone (again Google search will tell you how it is a key combination) plug it into the computer via USB.
Then fire up Odin. Click on the PDA icon. Select the. tar file you downloaded earlier (likley in your download folder) and click start on Odin and after 10 min your phone will have a factory image. Some of your data will stay some won't. The SD card isn't touched. Hope you backed your internal storage up although it usually doesn't mess with it.
Link to odin:
[Only registered and activated users can see links. Click Here To Register...]
This is a link to the download file. It is actually in .tar format. not SBF. This is ok. do what the instructions say in this lik and you'll be good.
This also tells you how to put it into download mode.
You will have questions I'm sure so ask them here and I will answer or someone will. .
Sent from my DROID RAZR using Android Central Forums
