Results 1 to 5 of 5
- 03-18-2013, 06:46 AM
Thread Author #1
- 03-18-2013, 06:48 AM #2
Re: How to smash microphone..?
Use a needle as a chisel, with a small, light hammer to add force. Why do you want the thing destroyed?
Sent from my HTC One X using Android Central Forums
HTC One XL, rooted, ROMmed, and S-OFF!
- 03-18-2013, 08:12 AM
Thread Author #3
OK... That sounds like a good idea.
One thing I read elsewhere... just pour water into the microphone bit, and nowhere else, but that sounds a bit dumb....
OK... so... I'll try your needle idea. Thanks.
I will ask though.. what will this do...? Is this just going to damage the mic, so the sound is garbled/non-existent... or are you saying this will remove the mic from the motherboard?
As for why I want it removed... let's just say, for security reasons. - 03-19-2013, 06:13 AM
Thread Author #4
- 03-19-2013, 06:35 AM #5
How to record audio via bluetooth headset not phone microphone
By simplejv in forum General Help and How ToReplies: 2Last Post: 05-02-2013, 05:48 AM -
How to use bluetooth as audio only and call with microphone
By edgars93 in forum General Help and How ToReplies: 0Last Post: 03-03-2013, 05:32 PM -
How to change Gmail address in G1?
By reddevilboyz in forum T-Mobile G1Replies: 2Last Post: 12-19-2012, 02:34 AM -
How to get flash to work on Hero
By Eman in forum HTC HeroReplies: 2Last Post: 08-01-2010, 08:22 AM -
How to test a G1
By Clackamas in forum T-Mobile G1Replies: 1Last Post: 08-05-2009, 10:34 AM
Reply
