Results 1 to 4 of 4
    Oimie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help: "SD card is being used as a mass storage device"
    I need help with my Samsung Galaxy S2 i1900 guys. I cannot access my gallery and anything associated with it (camera, some apps and etc.). When I attempt to open gallery (and others) I receive a pop up that says "SD card is being used as a mass storage device" I didn't drop it or mess with the settings. This problem just came out of nowhere.
    More details:
    - Occasionally I'll get a notification on the scroll down menu that says "USB storage damaged. It may need reformatting."
    - When I connect it to my computer with the USB, the drive doesn't show up on "My Computer" (it usually does). IT DOES HOWEVER show up on my "Devices and Printers" on the "Control Panel" as a connected device.
    I already did some researching on Google and found no solution that works. Anyone had this problem before and fixed it? Anyone have any idea how to fix it? I'll reformat or Factory reset if I need to, but I want to see if there are any alternative solutions since I don't want to lose my files. Thanks in advance.
  2. #2
    whitecollar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help: "SD card is being used as a mass storage device"
    Do you have a card reader on your computer available to you? If so you could try taking the sd out of the phone and putting it in an adapter and reading it that way.
    Oimie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Both the Micro SD and the card "inside" of the phone is not working. The Micro SD that I bought came with an external USB plug. I tried using it today and the computer could not go into the files. It is just greyed out on "My Computer" as "Removable Disk (F". And when I double click it, it says "Please insert a disk into Removable Disk (F"
  4. #4
    Rowena Rosello's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    what does it mean? sd card beign used as mass storage device?
  1. HELP! "SD card is blank or has unsupported filesystem"?!?!
    By jacquimartin1225 in forum Introductions
    Last Post: 04-09-2013, 06:08 AM
  2. it seems my sd card is being read but not acknowledged
    By justconfused in forum Android 2.3 Gingerbread
    Last Post: 03-29-2013, 02:50 AM
  3. Can an Android phone be used as a WiFi only device?
    By MrBigFeathers in forum General Help and How To
    Last Post: 10-13-2011, 07:40 PM
  4. How do i know if my sd ext is being used..
    By thexxoffspring in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 10-09-2011, 11:54 AM
  5. Please help phone bricked and sd card is wiped!
    By AshAshPixieDust in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 08-02-2011, 10:52 AM
