Need help making GO SMS my default on Android 4 Razr Maxx
modoc_us
13
I apologize in advance if this has been answered, my search string did not pick it up.
Running the newest version of Android that was released today 03-24-2013
I went into GO SMS and set it to default within the application, but I guess android has a setting that is overriding Go.
Anyone know the answer?
Thanx in advance,
zkSharks
Retired Moderator
Mar 15, 2011
2,013
75
If you're referring to the default messaging app for composing a new message, go into your contacts list, select a contact, and select the text message option. It should prompt you to select which application you wish to use. If it does not, you need to go into Settings > Apps > [Stock Messaging App] > Clear Defaults. Then repeat the steps above, and it should ask you which one. Select GoSMS, and ensure you select the "Always" option.
modoc_us
13
man, with earlier versions it used to be so much easier lol. I thought the purpose of upgrading software was to make things easier not harder. I was hoping to use GO SMS for all contacts.
modoc_us
13
Appreciate the help Patrick, but Clear Defaults is already grayed out. Gonna try to reboot my phone, but I dont see that as solving the problem.
