Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By cordoni
    Default Need help making GO SMS my default on Android 4 Razr Maxx
    I apologize in advance if this has been answered, my search string did not pick it up.
    Running the newest version of Android that was released today 03-24-2013
    I went into GO SMS and set it to default within the application, but I guess android has a setting that is overriding Go.
    Anyone know the answer?
    Thanx in advance,
  2. #2
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Default Re: Need help making GO SMS my default on Android 4 Razr Maxx
    If you're referring to the default messaging app for composing a new message, go into your contacts list, select a contact, and select the text message option. It should prompt you to select which application you wish to use. If it does not, you need to go into Settings > Apps > [Stock Messaging App] > Clear Defaults. Then repeat the steps above, and it should ask you which one. Select GoSMS, and ensure you select the "Always" option.
    man, with earlier versions it used to be so much easier lol. I thought the purpose of upgrading software was to make things easier not harder. I was hoping to use GO SMS for all contacts.
    Appreciate the help Patrick, but Clear Defaults is already grayed out. Gonna try to reboot my phone, but I dont see that as solving the problem.
  5. #5
    cordoni's Avatar
    Posts
    Global Posts
    943 Global Posts
    Carrier
    Stock
    Doing it the way stated above will default for all contacts.
    Sent from my DROID RAZR using Tapatalk 2
  1. Need Help With Go SMS Backup and Restore
    By music_man185 in forum Android Apps
    Last Post: 11-25-2012, 11:45 AM
  2. I need help making a Custom Recovery for my Optimus S
    By CCGOD in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 09-04-2011, 02:52 PM
  3. Need help with an extremely annoying issue on my Incredible.
    By acman319 in forum General Help and How To
    Last Post: 03-15-2011, 08:56 PM
  4. Needs help with connecting to my facebook account
    By jaaythib in forum myTouch 3G Slide
    Last Post: 07-02-2010, 11:20 AM
  5. I need help installing fresh 1.1 rom on Hero!
    By Zerazac in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 01-21-2010, 08:15 PM
