Help?! My Samsung Galaxy S will not let me download apps!
CalicoTabby
5
Hello, I'm new to this site but my phone has been making me frustrated so I found this site in willing to get help.
My phone is a Samsung Galaxy S.
Since I got it I've been trying to get free apps from the Google Play store but every time I try to get an app it says "Package file is invalid."
I have Gmail already on my phone and it works perfectly, but every time I try to do updates it says the same thing.
Any help?
Any help?
Try this:
How to fix Package file is invalid error on Google Play Store - GizmoStorm
Remove your Google Account and re-log in. See if that helps. Also try deleting the Play Store updates/cache form the device by going into Menu > Settiings > Apps > Play Store
HELP PLEASE!!!!
I have had a Samsung Galxy S for a couple of years and have never had "Google Store" I can only download apps from Samsung. How do I get Google Store? I only have the "Market" App on my phone. Think I have been sold a dud and wasn't aware of it. :-(
I had a similar problem to yours, but i had a Samsung Galaxy S Plus and the thing i did was clearing my cache and then it worked.
But as i read the other posts it doesnt seem to help you.
HELP PLEASE!!!!
Just enter "Market" and it should automaticly ask about it or update to Google Play. It did for me when i had "Market" Try that.
You can download any app that's compatible with the phone. You can't download apps that aren't compatible with the phone. NO one can change that. (Even if you managed to download a Kit Kat app and tried to install it, it either wouldn't install [usually a parse error] or it wouldn't work once it was installed.)
slackingfred
