Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By CalicoTabby
    Default Help?! My Samsung Galaxy S will not let me download apps!
    Hello, I'm new to this site but my phone has been making me frustrated so I found this site in willing to get help.
    My phone is a Samsung Galaxy S.
    Since I got it I've been trying to get free apps from the Google Play store but every time I try to get an app it says "Package file is invalid."
    I have Gmail already on my phone and it works perfectly, but every time I try to do updates it says the same thing.
    Any help?
    Justin Lucas1 likes this.
  2. #2
    Default Re: Help?! My Samsung Galaxy S will not let me download apps!
    Quote Originally Posted by CalicoTabby View Post
    Any help?
    Try this:
    How to fix Package file is invalid error on Google Play Store - GizmoStorm
    I tried everything it told me and it still wont work.
  4. #4
    lyeileen's Avatar
    Posts
    Global Posts
    26 Global Posts
    Whether you set permissions in your phone?
  5. #5
    Is your phone rooted?
    Sent from Squishy's N⁴
    what does that mean? = w =
  7. #7
    Haha nevermind then lol
    Wipe data/and clear cache data
  8. Thread Author  Thread Author    #8
    not working :c
    where do you go to do that?
  10. #10
    srkmagnus's Avatar
    Posts
    Global Posts
    13,691 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Remove your Google Account and re-log in. See if that helps. Also try deleting the Play Store updates/cache form the device by going into Menu > Settiings > Apps > Play Store
  11. #11
    Go to your play store app through ur setting as in go to settings>applications>Google play>wipe data
  12. #12
    HELP PLEASE!!!!
    I have had a Samsung Galxy S for a couple of years and have never had "Google Store" I can only download apps from Samsung. How do I get Google Store? I only have the "Market" App on my phone. Think I have been sold a dud and wasn't aware of it. :-(
  13. #13
    I had a similar problem to yours, but i had a Samsung Galaxy S Plus and the thing i did was clearing my cache and then it worked.
    But as i read the other posts it doesnt seem to help you.
    Quote Originally Posted by CathieG View Post
    HELP PLEASE!!!!
    Just enter "Market" and it should automaticly ask about it or update to Google Play. It did for me when i had "Market" Try that.
  14. #14
    my phone wont let me download apps is it because of its age i have a galaxy s
  15. #15
    can you help me
  16. #16
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    You can download any app that's compatible with the phone. You can't download apps that aren't compatible with the phone. NO one can change that. (Even if you managed to download a Kit Kat app and tried to install it, it either wouldn't install [usually a parse error] or it wouldn't work once it was installed.)
  1. Replies: 1
    Last Post: 12-16-2012, 08:33 PM
  2. Play store not letting me download apps.
    By daniel2744 in forum Sprint Galaxy Nexus
    Last Post: 09-26-2012, 06:19 PM
  3. Help my Samsung Galaxy s2, got problem unknown baseband and imei
    By sorsaopiseth71 in forum Samsung Galaxy S II
    Last Post: 08-14-2012, 04:32 PM
  4. Help my Samsung Galaxy s2, got problem unknown baseband and imei
    By sorsaopiseth71 in forum Continuum Rooting, ROMs, and Hacks
    Last Post: 05-04-2012, 11:27 PM
  5. galaxy tab will not let me access settings tab?
    By edarby00 in forum Samsung Galaxy Tab
    Last Post: 08-25-2011, 11:33 AM
