Kyocera rise boot loop trouble
Houston McCullum
Ok I've recently just rooted my phone because I wanted to see emojis. So when I downloaded font installer
And used it to reboot, my phone has been turning on and off with only the booting screen (I think that's what you call it).
And so I tried restoring it back to factory settings through the recovery
Mode, and I reboot it, it does the same thing (in boot loop). PLEASE HELP IDK WHAT TO DO!
try a master reboot. hold the volume down button and the power button at the same time (takes about 15 sec) the andriod guy pops up and it will then have 3 options on the screen. reboot, data reset, and reset cache. first reset cache(so you wont lose data) then reboot. (power button selects) if it doesnt work restart process but this time reset data. you will lose all apps except music and pics
i tried the factory reset, but i'm still stuck in a boot loop. even after the reset it still says E:cannot load volume /misc!
I need to re install the original rom, to get it back to working again. does anyone have a link to the original rom?
thanks
Lelix2603
