help!
hilariousted
I have a galaxy s Blaze 4G and i recently have been having trouble with. When i put in my beats by dre ear buds, only my right bud plays audio while the left bud plays no audio! Any help ?
Try the DRE's on other music players or try other buds on the Blaze. You can easily find out the problem with the method I showed you.
I know this sounds like a dumb question, but are you sure the headphone plug is fully inserted into the jack? With some devices, it really requires a strong push until you hear or feel it click into place.
The other thing to try would be to clean out the headphone jack. Try swabbing it out with a Q-tip dipped in rubbing alcohol, or using a compressed air can to blow it out.
Yes that's correct when I first got my S3 the same thing happened. You have got to push it in hard on some devices then it goes in. Sorry forgot about that.
slackingfred
