[help] custom recovery for Richtel A1 needed
samex2050
Hi I have china android spreadtrum device. I have already tried many cust. recovery, but none of them are supported. Some shows white screen in recovery mode and rest nothing. I have rooted my device successfully. But stuck with custom recovery. If anybody can help, please help
My device details are given below
android: 2.3.5 baseband hardware: sp6820a cpu hardware: mt6515 Gsm modem: sc8810 Phone brand: alps Cpu speed: 1ghz Cpu model:ARMv7 processor rev 1(v7l)
Hi samex2050.. I own a Richtel A 11.. Can you please tell me how did you root your phone and how to get the device details?
I am unable to connect my rich tel A-1 mobile to windows 7 p.c.via usb cable,
The details of my phone are as android version 2.3.5 baseband version MAU.11AMD W11.37.SP>V16/04-20-2012 kernel version2.6.35.7,software versionZXL-K880C-7-VO-2 and hardware version is 1.1.0. Also its memory card-SD cared is also not connected via usb cable i.e.usb connectivati option is not available/untracb le
- - - Updated - - -
download a program called vroot. its in chinese, but i will help. after you install the program unzip and install it to your desktop. do not plug in device yet!! after you have the vroot up and running, power off your device and plug into pc...only do this if your device is not yet rooted.
if u are rooted...then download an app from the market called nandroid manager...
you must find a recovery and install it to your pc...here is a link....i used
cwm-recovery-Feiteng_GT-A7100.img!
download this to your pc. and put on the root of your sd card.. from the device unzip it and look for the icon that looks like a book. i used es file explorer... go to nandroid manager and go to the part that says flash recovery. make sure u chose the .img file and not the zip. this is why u must unzip from your phone. do that and your device will have cwm.... to double check, power off device and wait a minute. then hold volume down and power until the cwm recovery comes on.
I have recently purchased Richtel MObile A-1`android version 2.3.5 kernel version2.6.35.7 software version 2x-lk880c-07vo-2 and hardware version 1.1.0 main problem of this mobile that it is not connected to my windowz 7 computer and net work is always disconnected. Kindly provide suitable solution for this problem also let me know whether any latest software is available for this model.
r3dpuk3
