Home Screens in Samsung Galaxy S3.
mvrkrishna
Hi,
Recently I bought a Samsung Galaxy S3 phone. I read in one of the forums that Galaxy S3 has 7 home screens. But, the phone i bought has only 6 home screens. Could any one help me How to add the 7th screen?
Regards,
Rama Krishna
While on a home screen, look at the bottom of the screen. You should see 7 small squares, with one highlighted, indicating which screen you are on. Perhaps you are scrolling to a screen that currently has no icons on it (an unused screen)?
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
FYI, there are 6 small squares. Highlighted one is the 4th one. There are 2 small squares to the the right of the highlighted one and 3 squares on the left hand side. The 6th one i.e. the last screen is not having any icons in it. What should i do add the 7th one?
I've never heard of this before. Try this: go to <settings>, <home screen>, and see which "mode" you are using, easy or basic?
I am using basic mode, but when I changed it to easy mode, I had only 5 home screens available.
Hope this helps.
kuzmaj05
