Samsung Note II VZW - No data from WiFi or cell signal
GeneralDon
As the title says, I'm getting no data from my home WiFi or 4G from the cell signal, despite them being shown as connected.
I noticed it just a few minutes ago. I was looking into Voodoo RootKeeper because I haven't updated to the latest OTA update and I've been wanting to soon, it was mentioned that SuperUser should be fully updated for it to work. While looking through SU settings, I noticed the option to set SU as a system app, so I did it. It rebooted and just before finishing the boot it had a message saying something about configuring apps (similar to what you would see after an update, I believe). Once it finished I was going to update some apps that needed updating and Play said it had no connection, checked Chrome and it was the same story. So here I am.
My Note II is on Verizon, it is rooted, also has an unlocked bootloader (which is why I've waited so long to do the OTA). I haven't updated since I got it at the beginning of December last year, so the current version I'm running is 4.1.1
Any help is really extremely appreciated; my smartphone becomes a dumb phone without any networking, dumb phones make me sad :'(
Edit: I fixed it, somehow. I unrooted with Voodoo, tried to complete the OTA update (failed because of recovery or something), re-enabled root after update, and then I had data back. Leaving this post here in case someone comes across a similar problem.
r3dpuk3
