Any way to quickly check permissions (including disabled, if possible)?
Continuum88
70
Permissions Denied seems like a neat app to tweak permissions of apps, but it takes a while to load (i.e. it reads app permissions on run, and this could take a while). So when you just need to check some app's permissions (hopefully also those that you disabled by means of Permissions Denied), is there any quick way to do it (other than opening play.google.com in your browser and checking the app's homepage...)?
You should be able to see an app's permissions by simply going to Settings/Apps, and selecting the app. Scroll down, and you should see a list of Permissions.
Thanks. It does show the permissions, including SU, but doesn't indicate whether any of them have been disabled by Permissions Denied. Is there also a quick way to check those?
Oh I see. Not in stock Android--not that I'm aware of, anyway.
slackingfred
