1. PrevailGFX's Avatar
    Is there a way to charge my phone with a broken charging port?
    Will this work? Charger any battery with a Universal Battery AC Home/Wall Charger, Travel Chargers
    Also, is there any way to buy a new battery cover for my phone? Motorola Triumph
    04-28-2013 07:04 PM
  2. meyerweb#CB's Avatar
    Amazon.com: motorola triumph battery charger
    motorola triumph back cover replacement | eBay
    04-28-2013 07:16 PM
  3. PrevailGFX's Avatar
    "0 results found for motorola triumph back cover replacement" Looked through for a while, didn't find anything...
    Lot of things that "claim" to work to charge the phone, but I've seen lots of bad reviews that they don't work, looking for someone who can vouch for one that says it works.
    04-28-2013 07:22 PM
  4. Voliam's Avatar
    This is a common problem with micro USB ports. For the price of a third party charger, you might be able to get it repaired by an independent phone repair shop.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    04-29-2013 04:25 AM
  5. cellunex's Avatar
    Solder has been degraded by new material standards. More tin and less lead in solder material. That make solder joint connections more brittle. Anyway the UBOC Universal battery charger can charge your battery. eBay has them. One size fits all. Hope that helps! I know it has helped many people with this same problem.
    11-23-2013 06:49 PM
  6. Rukbat's Avatar
    Replacing the microUSB port might be a little bit more than a universal charger (which will work - I use several of them for various sized batteries). It just keeps the phone out of use for the time it takes to charge the battery,
    (The port and associated board with most phones is in the $20 area - double that if you have to pay for labor.)
    11-23-2013 11:06 PM
  7. Jenny Bell's Avatar
    how to get my samsung galaxy charger piece chargin my phone
    11-27-2013 04:40 PM
  1. Samsung galaxy note phone - usb charge flex power port problem
    By mceochaidh in forum Samsung Galaxy Note 2
    Last Post: 02-21-2014, 10:55 PM
  2. Using phone while charging
    By Noseeums in forum Motorola Droid
    Last Post: 08-29-2013, 09:55 PM
  3. Phone Not Ringing When Charging Off PC USB port.
    By DirkBelig in forum HTC EVO 4G
    Last Post: 11-30-2010, 05:59 PM
  4. Charge phone + spare battery at same time
    By pcguys in forum Epic 4G Accessories
    Last Post: 09-04-2010, 11:28 AM
  5. Replies: 11
    Last Post: 07-07-2010, 01:34 AM
