Superuser problem, please help!
MrKrour
4
Hello guys,
Well my problem is that after I get my Galaxy s3 I did the software update to jelly bean 4.1.1 after that I was searching for apps fyou know as its my first Android device, I found that you can buy everything for free, you just need to download superuser, so I did that I downloaded it, after that It didn't work it just keeps failing to get root access, so I ignored it as no big deal.
And now after a while I saw that there's no notifications for new software updates.
So I entered my settings and I found it modified
Is there anyway that I can delete the superuser without root access.
And what should I do to get updates.
Sorry for my bad English, thank u!
knightrider85
