Results 1 to 6 of 6
    scramer's Avatar
    Posts
    Global Posts
    75 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can't connect HTC EVO to PC with usb cable
    please help. After updating to 2.2 (I do not know that this is the cause, this is just the first time that I noticed it) when I connect my HTC Evo to my computer nothing pops up on my phone asking me what I want to do, nor is there a notification on the phone telling me that I am connected. It worked a week ago.
    Default Connection > Disk Drive
    Ask Me about USB connection type whenever I connect my phone to a pc is checked.
    On my laptop, it will show a removeable drive F, but if I click on it, it will ask me to "insert a disk".
    I tried my husband's HTC Evo (which has not been upgraded) and it will connect the way it is supposed to, so it is not the cable nor my laptop.
    Any thoughts?
    Thanks.
  2. #2
    Dirrk's Avatar
    Posts
    Global Posts
    245 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Do you have debugging enabled?
    scramer's Avatar
    Posts
    Global Posts
    75 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Dirrk View Post
    I had to go look up where that was. No, it is not enabled, and I forgot to add I am not rooted (if that makes a difference or not). and let me add that it was the official HTC 2.2 OTA upgrade.
    Thanks.
    scramer's Avatar
    Posts
    Global Posts
    75 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    update: the main purpose for this was to switch out sd cards. after removing the battery to remove the sd card (and swapping out info the difficult way instead of using the phone as a drive i might add) and reinstalling the battery, I thought I might try again, the options are now available to me.
    Moral: try removing and reinstalling the battery.
  5. #5
    rsheffey's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I am haveing the same issue, not rooted, update is also officeial, let me know if you figure anything out for this.
    scramer's Avatar
    Posts
    Global Posts
    75 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by rsheffey View Post
    i fixed it by pulling the battery out, waiting a few minutes, then putting the battery back in.
