1. pamberi's Avatar
    Greetings.
    I hope someone can help.
    I am new to the Android OS. I had a samsung Galaxy ace2 but bought a samsung S duos because I have a personal and work number and wanted to avoid carrying 2 phones.
    The phone uses android 4.0.4
    I cannot get the mobile data connection to run on 3g/hsdpa, it will only run on gprs and is thus very slow when I am away from a wifi connection.
    I have gone to settings/more settings/mobile networks (then changed to sim1 which is my preferred data provider) and the option "use packet data" is ticked/active. The APN is, I think, correct - set to TMobile.
    Still only gprs connection?
    Anyone able to help?
    Many thanks
    05-05-2013 06:37 AM
  2. HarrySDuos's Avatar
    Did you get anywhere with this issue? I'm having the same trouble.
    Harry
    07-03-2013 09:16 PM
  3. Casper Hannsen's Avatar
    Hi guys,
    Have you found any solution for this problem? I am having the same trouble.
    I moved recently to the US, and my carrier is T-Mobile. Back in Europe I had fantastic HSPA+ connection speed.
    Does it have something to do with the Firmware update recently released by Samsung.
    Any help is appreciated !
    Regards
    Casper
    07-08-2013 11:10 PM
  4. strathus's Avatar
    u need to know the exact frequency of the hsdpa your operator uses, and confirm if your mobile works with hsdpa in the same frequency.
    12-19-2013 05:26 AM
  5. Haptik's Avatar
    Go to Settings>More>Mobile Networks>Network Mode and choose WCDMA(preferred)/GSM
    12-19-2013 07:12 AM
  6. pamberi's Avatar
    Thank you! that worked
    04-19-2014 10:36 AM
  1. No service on samsung galaxy s ii after root/unroot
    By in trouble in forum Introductions
    Last Post: 06-03-2013, 07:05 PM
  2. 3G on Samsung Note N700
    By n700.android in forum Android 4.0 Ice Cream Sandwich
    Last Post: 09-10-2012, 05:27 AM
  3. no 3g on cm7?
    By madrob78 in forum HTC EVO Shift 4G
    Last Post: 05-21-2012, 08:18 AM
  4. How to Manually Switch to 3G on Samsung Infuse 4G
    By XWingz in forum Introductions
    Last Post: 05-16-2011, 11:29 PM
  5. Talking On Phone = No 3G/WiFi Access
    By ChocoBilly in forum Motorola Droid
    Last Post: 11-21-2009, 02:25 PM
